Hello Wing Cheung,
When you are referencing in the map when you say "only show the submission in the map for a specified period of time", are you talking about a Web Map in ArcGIS Online/Enterprise or are you referring to the map on the Data tab of the ArcGIS Survey123 Website?
If you are referencing a Web Map in ArcGIS Online/Enterprise, by default Survey123 surveys should have editor tracking automatically enabled so you can apply a filter on the data to only show records after a certain submission date for example.
If you are referencing the map on the Data tab of the ArcGIS Survey123 Website on the top left you can filter by submission date or another attribute in the survey.
Thank you,
Zach
Thank you,
Zach
