While the above method works to get the Scenario running again in Integromat, the token expires again in 2 weeks.
Is there a solution that will refresh the token automatically when using the Survey123 "Watch Survey" module in Integromat? It would be great is somebody could paste clear instructions for doing this, I've seen other more complicated replies for doing this using JSON but it doesn't seem like this should be necessary if using the Watch Survey module, isn't there a simple solution?
