Hi Bryce,
The calculate question type is intended to hold values that do not need to be displayed in the form but are included in the feature service. As you found, you can use other field types (integer, decimal, text...) and apply the calculation in the calculation column.
Note, that if using a string type of question to perform a calculation that will result in a numeric value, you will likely want to use the 'int(${question_one})' syntax in order to ensure that the result is recorded an an integer. This will allow for the result to be used in further numeric calculations.
Formulas—Survey123 for ArcGIS | ArcGIS
Brandon
