Multiple constraints expression for a field?
544
07-14-2023 09:46 AM
BryceHancock
Hi, I have an integer field where I have added the following expression to the constraint field:
.>0 and .<360 or .-99
I want the user to be constrained to enter numbers between 0 and 360, or allow a -99 to be entered. Can this be done with a constraint field? If so, what is the proper expression?
MobiusSnake
MVP
(.>0 and .<360) or .=-99
MobiusSnake
MVP
BryceHancock
Thank you, it appears
.>0 and .<360 or -99
, works as well.
