Multiple selections on each form
764
09-26-2016 09:04 AM
PatrickHannan1
New Contributor II
I'm creating a form for a tree survey. We have a 30' radius and sample every tree inside the plot. Is there a way to set up the form so I can note every tree (number of trees in plot varies from sample site to sample site) and just have one form for each site? Or would I have to create a new form for each tree inside the each plot?
Tags (1)
DerekLaw
Esri Esteemed Contributor
Hi Patrick,
Yes, you can use a single survey for all the trees in the sample plot. You can simply collect info about each individual tree within a repeat question. Please see the attached sample tree survey form to help get you started.
Hope this helps,
DerekLaw
Hi Patrick,
Hope this helps,
