Hi All,
I am having a problem with a very dynamic survey where the position it returning a wrong value in a nested repeat when retrieving a survey from the Inbox. I have attached my survey supporting lists and a screenshot walkthrough of the issue... All data is in the service properly, but the windows/android 3.13.234 and iOS 3.14.182B clients have all shown the problem.
Larry
With nested repeats position(..) gets confused so you need to be specific. position({repeatname})
Hope that does it
Hope that does it
Thanks Doug, your solution and looking at what we had found an issue with missing .. and tightened up out nested repeats by adding the position(${repeatname})!
THANKS!
