Odd or Even Integer Specification Survey123 Connect
575
12-09-2022 08:55 AM
FloraGibbs
New Contributor II
Is there a way to specify only odd integers can be entered into an integer field using Survey123 Connect?
jcarlson
MVP Esteemed Contributor
Survey123 supports a modulus operator, so you could to ${odd_question} mod 2 = 1 in the constraint column. This would ensure that even integers are rejected.
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
FloraGibbs
New Contributor II
Amazing thank you!
