once(join()) work differently on the first repeat
791
5
03-14-2022 01:27 PM
DougBrowning
When I use once(join)) inside of a repeat the first records works differently.  It adds it right away where all other repeats adds it after the move to the next repeat.  I am trying to get around this using position but I use pages which means it is in a group which means it always returns 0.
First repeat
Second repeat is the same
3rd repeat see how the last value is not on the list.
I maybe got around it by counting a field in another field after the list and then checking that field to adjust my check.  May not make sense but it seems that the order matters.  So if I count a field before that field I do not get the count you are on but if I count it after I do get it.
by Anonymous User
Not applicable
Hi @DougBrowning,
Does this appear to be new or different behavior with the recent 3.14 release, or did you see the same thing before with 3.13?
Are you able to send us this form (updated copy) so we can take a closer look?
Phil.
DougBrowning
I think new to 3.14 but not sure.  I had to change the code since 3.14 broke my dups check trick.  I ended up having to code around it by checking if it was the first repeat.  This was actually hard since I had to count a field that was after the constraint field - which took a few hours to track down.
if(${TempCount}=0, 1,${Species}='' or contains(${Species}, "XXXX") or not(contains(${AllPlantsCheck}+",",${Species}+",")))
I will email you the form.  Thanks
by Anonymous User
Not applicable
Thanks @DougBrowning,
Got your email, we will take a look and get back to you.
Phil.
jrowe19
Hi @DougBrowning and Phil. Was this ever resolved? I am having the same issue. Thank you!
DougBrowning
Update to myself.  2 years later and it is still doing it.  I finally found a fix.  If you set your count field that has a calc of 1 to also have a default value of 1 then the repeats calc properly.
