one form two fgdb
287
09-14-2018 09:55 PM
G_A_Venhorst
New Contributor II
Hi, Vraag me af of het mogelijk is om met 1 formulier twee of meer FGDB te vullen?
Hi, Wonder if it is possible to fill two or more FGDB with one form?
IsmaelChivite
Esri Notable Contributor
Hi.  Not directly. Survey123 works against Feature Services.  Feature Services do not work against File Geodatabases.  Surveys are configured against a single layer within a feature service and can work with that layer and related tables and layers.
Having said this, you can schedule ETL processes (with FME or simply with some Python code) to get Survey123 data out into FGDBs.
