ArcGIS online popup config, custom attribute display.
I included a link to survey123 in the correct format, but I cannot pass data from the clicked feature to any survey123 fields that are type: "note" or "hidden".
&field:hidden_name={featureService_fieldName}
I checked the schema field type of the hidden and note field and its string, this matches the feature service attribute type.
passing data to a survey123 type: "text" field works fine, but it has to be editable, i.e. read_only = "".
I'm just trying to link clicked features to forms, WITHOUT the field being editable in survey123. If you pass a string to a type: "text" field in survey123 it works, but what happens when the user edits that field...you no longer have joinable data.
This is why I wanted to pass a value to a hidden or non-editable field but I just cant....
any ideas?
