Hi @IsmaelChivite
Thank you for your quick reply. I have looked at that example, but didn't think it was what I was looking for. The polygon in which I have in my basemap in Survey123 connect does not a have a field in which I want to pull data from. I'll explain further below.
In that example, if I'm understanding it correctly, it is depicting making a point - but that point HAS to be in Spain which has been pulled from a layer that has a Countries field in it with Spain in the attributes.
In my case, since I am making a point and wanting to check simply if that location chosen is within a buffer of a lake - do I need to have a specific field in the buffer layer from which I can pull the data from?
For example, I could make a 250foot field in my polygon layer and have the attributes be yes/no. In the text question type, I would pull data from that field and set the constraint on the geopoint to be ${250foot}="yes" and the constraint message to The location is not within 250 feet of the lake.
Please let me know your thoughts.
Thanks in advance!
