Hello James Tedrick, Ismael Chivite,
I am attempting to create the following calculation:
- If the value of {CANNOT_LOCATE} is set to 'YES' then set my current field to 'UNKNOWN'.
- If the value of {CANNOT_LOCATE} is set to 'NO' then don't pre-populate my current field and let the user choose from the list of choices.
I can achieve the first part using:
if(selected(${CANNOT_LOCATE}, 'YES'), 'UNKNOWN','')
However, if the value of {CANNOT_LOCATE} is set to 'NO' the value chosen for my current field is considered ineligible and gets the strike through as it's not ' '. So, I tried the following:
if(selected(${CANNOT_LOCATE}, 'YES'), 'UNKNOWN',if(selected(${CANNOT_LOCATE}, 'NO'), 'NO',''))
This works, and even if I change my current fields value from "NO" to something else on the choice list it's accepted. However, it does pre-populate my current field with a "NO" meaning a user could technically skip over this field. I'd much prefer to leave my current field BLANK if the value of {CANNOT_LOCATE} is set to 'NO'.
Any advice?
