Problem with multiple coordinates
803
01-25-2017 04:56 AM
ADMIngenieria
Good Morning.
I am generating a form using the Survey123 application.
Below and I indicate the problem that I am having.
The form takes a general location using the geolocation option. Then through a series of repeats a series of data and new locations must be taken.
At the end of the form the program does not issue errors, but when completing the form using the cell phone always throws the error code 1003- operation rolled back.
I tried performing the form without capturing the location inside the repeats and it works correctly.
i checked all the groups and they are well define.
Apparently the problem is in the form in which the repeats are established. (Since within repeats3, 5, 71, 81, 83 and 85 coordinates are taken)
thank you very much
Greetings.
JamesTedrick
Esri Esteemed Contributor
Hi Alberto,
Given the image you attached, it looks like you are attempting to have nested repeats (i.e., rep1 is a repeat from the parent form, rep3 - rep85 are repeats to rep1).  We currently do not support nested repeats in Survey123
ADMIngenieria
Thank you very much.
is there a way to take multiple geopoints using the same form?
JamesTedrick
You can capture multiple geopoints on a form by having a repeat group that contains a geopoint question.
