Publicly shared Survey123 Form requires sign in
353
02-13-2024 03:15 AM
PhilileKubheka
Hello,
I have created an advanced survey 123 form using Connect, and published and shared it publicly using Enterprise, however it is requiring that users sign in. everything is shared publicly, including the feature layer and the web map. I have verified the sharing setting in Survey123 website and republished, however I am still encountering the same issue. Is there another way to resolve this?
Tags (1)
DougBrowning
MVP Esteemed Contributor
There are some AGOL Organizations settings also.
Take a look at this post for all the things to check  https://community.esri.com/t5/arcgis-survey123-blog/securing-data-in-public-surveys-survey123-connec...
And maybe https://www.youtube.com/watch?v=2KdiVhj1icw
DougBrowning
PhilileKubheka
Hi Doug,
Thank you. The survey form is currently shared on Enterprise and not on AGOL. I have looked at the solutions posted above, and they are not assisting with the issue. I have public sharing rights; everything works fine except for the login pop up for the public. Is there perhaps another solution for this?
DougBrowning
