Hi, I am trying to use the submission URL in Survey123, I created a sample survey, published to ArcGIS Online and then exported the feature service as a FGDB. I then imported into my ArcGIS Server SQL database, it added the related tables, domains etc. I then created a feature service with update, delete etc.
I took the REST URL and added it as a submission URL, however when i go to republish the survey (as per Submission URL—Survey123 for ArcGIS | ArcGIS ) I get an error saying the service relationship can not be created. I tried a basic survey with one notes field, but get the same result,
It recognizes that the feature service is now different and it starts to work but then errors.
Is my workflow correct in that I can write back to a feature service without having to use an on-premise portal? Security all seems to be OK, ArcGIS Online is using ADFS and the ArcGIS Server is connected via AD on the same domain.
Any help greatly appreciated
Regards
Jamie
