"Something broke the parser" - error publishing!
3272
6
07-30-2021 01:31 PM
JCOSNatRes1
Hello!
I am experiencing an "Error converting XLSForm" issue. Error contains the language:  ODK Validate Error "Something broke the parser" when trying to publish my survey.
I've looked over previous comments with similar errors and am pretty sure that I:
     1) am not relying on any "relevant" statements in the survey, so shouldn't be getting hung up there,
     2) I believe none of my field names are too long or improperly formatted
Any help would be appreciated!  Still new at this.  Spreadsheet attached.
Ruth_JiatengXu
Hi @JCOSNatRes1
Thanks for sharing here! It seems like there is a comma missed in your concat() calculation.
Ruth
Ruth_JiatengXu
Hi @JCOSNatRes1
Ruth
BotanyJCOSNatRes3
Incredible.  Thank you so much, Ruth!  That was absolutely the problem.  I greatly appreciate your help!!
- Jesse
Arnaud_Brival
Hi @Ruth_JiatengXu
Appologies but I'm suddenly experiencing a similar issues. The XLS form worked like a brease before but I must have inserted a mistake somewhere but I'm absolutely unable to find it.  I was also unable to decifer (nor copy and paste) the error message given by Survey123.
If you have a tool to test or find out more about the error, Would you accept to have a look at this rather complicated Xlsform?
Ruth_JiatengXu
Hi @Arnaud_Brival
Thanks for sharing here, and I am sorry for the late response.
It seems like there is an extra "`" in the choice_filter column for your Operator_lzin question, see the screenshot below:
I have attached the XLSForm with the extra "`" removed, and this should work with no issue.
Ruth
Arnaud_Brival
Thanks a lot @Ruth_JiatengXu ,  It really took me a while to find this cryptic typo! Thanks!
rachelpapers
Hi Ruth
I came to this community page because I also broke the parser!
Your help with other enquiries made me realise I must have made a syntax error.  Because I'm a complete novice this is hardly surprising, but would you be willing to share your method for working errors?  What do you check first and next etc.   I have just started using the Survey123 connect form and don't know anything about programming; I'm used to excel telling me when I've omitted a critical character eg a parenthesis so will probably make a lot of errors there, but for example if I could break the parser with just an overlong field name then that would be the first thing to check?  I haven't looked to see whether there's a syntax checking scratchpad website (as I've found for html, where they show you what the formatting will look like for the input html coding, and vice versa - I've found that a handy way to learn what works).
I have been to the survey 123 troubleshooter which was useful in a way but didn't help me step through my form to diagnose my problem, whereas your solutions helped me think of the basic errors I could have made.
So for me in the end it turned out that it wasn't my long RELEVANT formula that was breaking the system, it was simply because I'd put one RELEVANT formula in same row as the field it referred to, instead of the row for the field that depended on its value.
Not an urgent query, as I've now solved my problem, but all tips gratefully received.
Thank you
rachel
