Hi Survey123 community,
Following an upgrade of our ArcGIS Enterprise to ArcGIS Portal/Server 10.9.1, hosted feature services that were created from Survey 123 Connect with a survey start and end time started returning an error on query;
{"error":{"code":500,"message":"JSONObject[\"respectsDaylightSaving\"] not found.","details":[]}}
This error is only returned for queries with the the start and end times in the outputFields, if manually querying the feature service for different attributes then the data is returned OK.
In the feature service definition, Survey123 Connect has created the feature service with a time zone defined, and the property: respectDaylightSaving (note the difference from the error, where it is looking for respectsDaylightSaving).
The timeInfo section of the layer definition in the feature service looks like this;
"timeInfo": {
"startTimeField": "survey_start_dt",
"trackIdField": null,
"endTimeField": "survey_end_dt",
"timeInterval": 0,
"timeExtent": [],
"timeReference": {
"timeZone": "UTC",
"respectDaylightSaving": false
"hasLiveData": false,
"timeIntervalUnits": "esriTimeUnitsMilliseconds"
Using the Server Administration API I can change the time zone definition to instead have the property respectsDaylightSaving. This corrects the error, and all queries return correctly. The new timeInfo section of the service is below;
"timeInfo": {
"timeReference": {
"timeZone": "UTC",
"respectsDaylightSaving": false
"timeInterval": 0,
"timeIntervalUnits": "esriTimeUnitsMilliseconds",
"timeExtent": []
While that resolves the problem, it isn't ideal to manually edit all services created by Survey123.
Does anyone know which is the correct definition? Is the bug with ArcGIS Server 10.9.1 in looking for respectsDaylightSaving, or is the bug in Survey123 connect for creating the service with the respectDaylightSaving property on the time zone?
The only reference I can find is in this ESRI blog post from last year that indicates it should be respectsDaylightSaving.
Recreating the Error
We are using Survey 123 Connect 3.13.246, and i can recreate the issue by publishing a new service using any template and adding the survey start and end times to the XLSForm;
type | name | label |
start | survey_start_dt | Survey Start Time |
end | survey_end_dt | Survey End Time |
Once the survey is published, and the hosted feature service created by Survey123 connect, if I then submit some records into the new hosted feature service it will start returning the respectdaylightsavings error above.
Thanks for any help resolving this, I have also submitted a support case for the issue (#02958232).
Andrew
