Hi All, @PhilipWilson (similar questions)
I have a survey defined with a setting of pages, then a repeat with an appearance or field-list and a relevant case that is not met until the user makes a select on the first page of the survey.
When the user fills out the data to make the repeat relevant, the repeat always starts in minimal mode, I would like it to start as it would is the appearance had no value (expanded) as I present the user several options on the screen that they are required to select at least one.
I have tried putting the repeat (no appearance) in a group (field-list) with the same results. I am looking for a way to not have the repeat minimal when it becomes relevant.
I have attached a sample, remove the relevant statements to see the differences.
Larry
