I have a survey where users can provide feedback on software including options for feature requests, or notify of bugs/errors. I am using the new Microsoft Power Automate Survey 123 Create Reports action (which is amazing by the way) and have successfully managed to get the flow to create a single report based on a survey when it is submitted and save to a SharePoint folder of my choosing as well as notifying me of the report. This flow has a condition to run when a the option of Bug/Error is selected in the survey
This is so that i can be notified if a bug is found and fix accordingly. However, I would also like to run a summary report from Survey 123 collating all records submitted including the bugs and feature requests once a week. I have found how to schedule the flow to run once a week at a set time, but am struggling with working out how to connect the survey 123 report creation and filter by survey date within the last 7 days?
I know that the dates need to be formatted from epoch to something more workable but am hitting a it of a wall
any ideas would be massively helpful
Hi. See attached XLSForm and corresponding Report template. To test this, publish the XLSForm making sure the name of your survey form is BugsAndEnhancements v2. If you choose a different name, then you will need to edit the template to reference your survey name accordingly.
Highlights:
${BugsAndEnhancements_v2 | where:"category = 'Bug' and submittedOn BETWEEN CURRENT_TIMESTAMP - 7 AND CURRENT_TIMESTAMP !important" | stats:"count,objectid"}
${#BugsAndEnhancements_v2 | where: "category= 'Bug' !important" | orderByFields: "submittedOn DESC" }... ${/}
This worked pretty good for me. I was able to schedule this and have the report run as expected. Hope it helps.
For context, you can go about scheduling reports in a couple of ways:
We will cover all of this in more detail in our upcoming Automate Survey123 Reports webinar. Hope you can make it.
