Hello,
I created a new survey using Connect 3.19.116 and I was able to submit the survey. Then, I was about to test it using URL parameter with globalId and Copy mode. However, it throws this error (see the image below).
This survey was published with version 2.5 or earlier, which is no longer supported. Please contact the survey owner to republish this survey with the latest version of Survey123.
I tested a simple survey using 3.19 and copy mode worked fine. Is there something that makes my survey recognized as old version survey? I used some
- html (table)
- jr:choice-name which does not seem working as expected, and deleted it but still nothing changed
- field-list/page appearance.
Other than that I cannot think about anything special that may contribute to the error.
It's very critical and hope to get some insights what causes this issue.
@ZacharySutherby I have not seen any bugs like this.. is it possible to take a look at the xls file I can send it to you?
