Survey123 app enable logging by default
746
05-03-2023 08:26 AM
Katie_Clark
MVP Regular Contributor
Is it possible to configure the Survey123 field app to have logging enabled by default within the diagnostics menu within Settings?
Sometimes the app will crash/close with no warning when someone is in the field, and it would be very helpful to have them send us the log information when this happens. However, we don't want to have to expect them to have to remember to turn on logging every time they use the application.
Best,
Katie
“The goal is not simply to ‘work hard, play hard.’ The goal is to make our work and our play indistinguishable.”
- Simon Sinek
IsmaelChivite
Esri Notable Contributor
Sorry @Katie_Clark  It is not possible to automatically activate logging. It needs to be done manually.
IsmaelChivite
Katie_Clark
Thanks for the response, @IsmaelChivite .
Do you know if this functionality has been requested before and/or considered by the design team? I'm happy to start an "Idea" post for it if there isn't one already?
Best,
Katie
- Simon Sinek
