Now that repeat aggregation is available in S123, is there a way to count only records in which a particular choice was selected? Basically to filter the count by the selection value - say like count(${defects} = 'none') but that doesn't work; I guess because it's boolean (?)
The aggregation will be of limited use to me without this capability. Thanks! cob
Hi there,
The count function doesn't support a comparison function. This could be accomplished by having an additional calculate field in your repeat with the comparison inside an if statement, resulting in 1 if true and 0 if false- then you would need to sum the new field to get the number that meet the criteria.
Yes I had that same idea today and it almost works, but it seems like the repeats are summed like strings instead of numbers when the if statement is used. So when I do if(${cond1}='n' and ${cond2}='n', 1,0) they are summed like this - 1st iteration = 1, 2nd = 11, 3rd = 111 and so on. Can I use the bind ESRI type to override it? Thanks, cob
Hi Charles!
Did you ever get this to work? I'm trying something similar but so far no luck. Seems like a pretty useful function so I hope it gets implemented as a standard function in future releases.
/Patric
Hi Patric,
To get this to work successfully, a column called bind::type needs to be added and the value set to integer for the question with 1/0 values.
