Philip,
Thank you for your response.
iOS Version is 11.3.1, model is MF010LL/A (Ipad Air)
- Without using the Bluetooth keyboard: Survey 123 crashes a 3rd party application mobile while it is supposed to be running the in the background. Also if you do not enter any information on the fields in Survey 123 and only open an entry, if you then use other applications, Survey 123 closes and does not save the open entry.
I tried the following combination which wielded this result.
- Open Survey 123, Select Route Sheet, and Select collect. I do not enter any information at this time.
- Open 3rd party application, Log in (I have to log in because as soon as I open Survey 123, it crashes 3rd party application Running in the background)
- Open an action order.
- Went to the address app to look for a random address, select an address and then look at the permits on that address.
- Open Safari, load Property Appraisers Page, enter a random address to look for.
- Return to 3rd party application It stayed open in the background with the Action Order I selected.
- Return to Survey 123, by this time it has logged out and the information is no longer available.
Again, since I did not enter any information it does not save that entry, if some information is entered it will save the entry and when I open the application it will prompt me to dismiss the info or continue that survey.
- For testing purposes I used a stop watch. The time I spent outside of the application before the information was erased was 3 Minutes and 44 Seconds.
- Yes, it lasts the whole day. After a full charge today the remaining battery today- without using Survey 123 was 38%. Attached is a breakdown of the average use of every app today. As well as the time the iPad was on. Today I acutally used my iPad for 3 hours and 13 minutes. All together the iPad was on 6 hours and 55 Minutes.
- Attached is a breakdown by percentage of battery use.
