Survey123 Form will not submit decimal numbers citing "Invalid number"
282
04-12-2024 05:29 AM
MlondiNdlovu1
New Contributor II
We designed a form which has worked fine up to this point. The issue occurs with decimal numbers only. A user is facing this issue in the screenshot below only when using an IOS device.
We have tested the form on Android and HarmonyOS devices and works as it should.
abureaux
MVP Regular Contributor
I don't have a solution off-hand, but I notice you are using a comma in place of a decimal. Out of curiosity, have you tried swapping to a decimal number to see if that works? If it does, then the issue should be brought up with Esri as a bug. If that doesn't work, you will need to provide your XLSX* so we can have a look at what is going on.
*If you can't post it publicly, please contact Esri support.
Edit: I am under the assumption that you can swap comma/decimal somewhere in device settings. But I don't know where off-hand since I stick with the NA standard of a decimal.
MlondiNdlovu1
New Contributor II
The standard used around here is a comma for a decimal point. Although, we did try to use the point (.) When we use it instead the entry for that field is returned empty.
Please see the XLSX*
abureaux
Are you sure that is the correct XLSX? I cannot find any of the fields referenced above. For example, this is what I see on page 4:
MlondiNdlovu1
New Contributor II
It's not the one from the screenshot. But the same issue (all esriFieldTypeDouble fields) has been reported by IOS device users on this form as well. I couldn't share the other one publicly.
abureaux
That's fine. I assume I should be looking at any of the decimals?
Since I don't believe I mentioned it yet, here is my obligatory: Please ensure Connect is up to date. Current version is 3.19.116. If you install from the Microsoft Store, it updates automatically. An out of date Connect can result in many unforeseen issues.
In the case of the decimals causing the issue... there really isn't a lot going on there. Can you clear the "bind::esri:fieldType" column and see if that has any effect?
Setting this for most values is redundant anyways since Connect automatically maps the "type" to a predefined "esri:fieldType". Generally speaking, most people only need to use the "null" fieldType.
Here is a list of automatic conversions:
'type' column
Esri fieldType automatically applied
text, select_one, select_multiple, calculate, hidden, email, start, end, deviceid, barcode, noteText
integerInteger
date, dateTimeDate
decimalDouble
geopoint, geoshape, geotraceGeometry (point, line, polygon respectively)
file, image, audioAttachment
If your issue persists after that, make a new survey and add in a single question type of "decimal" and see if that works on its own. This is essentially what you have in your main survey. If this works, something funky is going on. If this doesn't work, contact Esri Support and log a bug.
BTW, "Package" is a reserved field, so you should look at changing it as that can cause unforeseen issues.
Also, notes aren't added to the Feature Layer if you don't give them a "name". You can remove this note's "name" and "null" parameter for the same effect:
