I created a Survey123 form that collects data (of course), and taking a picture is one of the requested pieces of data.
When I go to the layer the form creates, and view it in Map Viewer, the image attachment links are there, but not shown as a thumbnail.
I found the tutorial about how to show it in the popup by adding a field and then calculating that field using an Arcade expression, but when I try to do that, the message I get is...
Arcade cannot be used to calculate fields in this layer because the layer has Sync or Keep track of created and updated features enabled
My assumption is that this means that since the layer is populated by a form, and the layer, thus, must be updated every time there is a new submission, this option of calculating the field does not work. I'm unfortunately not savvy enough to know for sure if that's true, much less what to do with that bit of information. I see SQL is still an option for calculating, but I'm unsure how to do that.
Is there a simpler way to achieve what I'm trying to achieve? Namely, to have images collected/submitted via a Survey123 form automatically appear in a popup, which I will configure to look pretty?
Thank you so much.
Jeb
