Hi James,
I am replicating this issue with beta version 3.5.124 and Portal 10.7.
No start or end questions, but I do have type time. Publishing services have been restarted using Server Admin.
Server Logs only report that the Manage Feature Service failed.
ERROR: Table not found. Failed to execute (Manage Feature Service).
I also see that the feature class and tables from the survey are not being created. Even though that step in the survey publishing appears to have worked. Service is created without any layers/tables.
My survey is large - around 400+ inputs in the survey.
*** UPDATE ***
I was about to post the above when I thought of testing this. I removed 300+ inputs from my survey (easy to do with my survey containing many groups - I simply cut/paste them to an excel file). I then successfully published the survey. Because my service was created, I then copied back in the 300+ inputs I originally removed, and republished the survey, selecting the option to add all of the new fields to my existing service. It's been about 1 hour and it's still on this action:
I cancelled that process, closed Survey123 Connect, reopened, removed 200+ of the 300+ inputs I tried to add, and started the process again. No improvement. So perhaps it is a limitation in survey size, however I doubt that is a Survey123 limitation vs. an ArcGIS Server limitation like heap size or something of the likes.
I'll continue testing to see if I can get more inputs added.
Chris B.
