Good evening, Ismael & James
it is very strange. today, I was planning to update one of my surveys. I downloaded from the server then updated a couple fields then I could not upload again. (i am getting error 400 and 401) thus, I did UNDO all my changes, but I could not upload my survey.
I attached few reference screenshots. I guess the "repeat" cause some issue.
please let me know if you have any idea.
thanks,
Hi Young,
Can you double check the capitalization of your fields and name of the tables? The update of Survey123 is now much stricter on the capitalization of fields (this was done due to requirements in properly supporting ArcGIS Enterprise implementations).
Hi Young,
On things that are already published, the key point is that they *match* what is present at the Service URL (REST API), not that they are lower case. The capitalization check does not apply to the choice tab.
As an alternative, could you try to generate a new survey from that feature service and see what differences, if any are present?
Looking at your endpoints, it seems the appropriate name for the repeat table is 'reserchresult', all lowercase.
I'm in the same boat:
https://community.esri.com/thread/198671-connect-publishing-error
I think @JamesTedrick was referring to your end group for 'reserchresult' which is not on your screenshot. One thing I learned that with or without a name on the end group also works. Placing a name on eng group just makes it easier to follow for nested groups.
As Braden, mentioned, the 401 component is the same issue that he has. Does your form contain a pulldata('@geopoint',...) function? As this isn't supported in the web form, the part of the API that generates the webform produces an error. It should not prevent the publishing of the form however- did the form get updated?
Hi again,
I do have the pulldata("@geopoint", ${geolocation}, "horizontalAccuracy","verticalAccuracy")..
yes, it should be prevented to publish it. somehow, the connector cannot find a folder. and the folder does not have a "form" data. please see the attachment.
thanks,
