Is there any way to use Custom URL to fill the Survey123 form fields from more than one layer at the same time?
The case is I have 4 feature layers in the same web map, I uses the custom URL to integrate the Collector for ArcGIS with Survey123.
In the form, I have several fields need to be filled from the 4 layers at the same form.
I know that i can populate several fields in same layer into form.
Thanks in advance.
