Use custom URL to fill questions from more than one layer
473
06-04-2018 05:35 AM
khalilramadeen
Is there any way to use Custom URL to fill the Survey123 form fields from more than one layer at the same time?
The case is I have 4 feature layers in the same web map, I uses the custom URL to integrate the Collector for ArcGIS with Survey123.
In the form, I have several fields need to be filled from the 4 layers at the same form.
I know that i can populate several fields in same layer into form.
Thanks in advance.
JamesTedrick
Esri Esteemed Contributor
Hi Khalil,
As the pop-ups are a per-layer configuration, it isn't possible to pass values from multiple layers directly.  You could construct a link through back-end DBMS or geoprocessing scripts that join together the data that needs to go across and have that available in one layer, though.
