Using Beta Reports - Error
1970
7
11-20-2017 01:45 PM
EmilyBartee2
Hello!  I'm working with the custom reports within the data tab of Survey123.  I've downloaded the default template (attached) and tailored it to be report specific (also attached).  Users can complete one of three damage assessments within the survey meaning two thirds of the input fields are not used within the report - thus a tailored report for that specific assessment.  While tailoring the fields and appearance I haven't changed or messed with the field names.  However, now when I go to print a report I receive an error stating "get errors when rendering the template" (image attached).  The default survey will give a printout but the one I've edited will not.  Any ideas?  Our survey uses many different groups but no repeats.  I'd appreciate any and all feedback, thank you!!
Emily
Tags (3)
by Anonymous User
Not applicable
I am now getting the same. Custom templates that previously worked are getting the error described above.
JamesTedrick
Esri Esteemed Contributor
Hi Emily, Damien,
Thanks for reporting this.  We are investigating the issues and will update.
ZhifangWang
Hi Emily,
Would you mind confirming if you just created the edited template in recent days and it never works or it worked before but just not working in recent days?
EmilyBartee2
This is an edited template I just created - it has not worked at all.  In the past I've made reports for different surveys and they've worked but this one has not worked from the get-go.  I appreciate the help, thank you!!
ZhifangWang
Hi Emily,
A fix is available on the Survey123 website today, would you mind to give it a try and let us know if it works for you?
by Anonymous User
Not applicable
Thanks. I tested it and it works…mostly. I’m not seeing values of “0” returned in the export (Percentage Slope: North).
The exported .docx
Thank you,
Damien Hoffman
Project Leader
Forest Service
Technology and Development
p: 406-829-6751
c: 406-214-7261
damienhoffman@fs.fed.us<mailto:damienhoffman@fs.fed.us>
5785 Hwy 10 W
Missoula, MT 59808
www.fs.fed.us<http://www.fs.fed.us/>
<http://usda.gov/>[Forest Service Twitter]<https://twitter.com/forestservice>[USDA Facebook]<https://www.facebook.com/pages/US-Forest-Service/1431984283714112>
Caring for the land and serving people
EmilyBartee2
I tried the beta export and the template now works.  Thank you all so much!!!
