Using choice_filter with select_multiple
163
2 weeks ago
dwold
Occasional Contributor II
I have 2 select multiple questions, the second having a choice_filter set on it. However, when multiple choices are selected in the first question, the responses disappear in the 2nd question. choice_filter reads: regex(area, ${mission_area}). I was following this blog for guidance.
Form (survey & choices):
Survey one selected:
Survey two selected:
DougBrowning
In the area column I do not think you can list all the options with a comma since it does an exact match search.  You need to break this out and list them multiple times, one for each area type.  At least I have never seen a comma lookup list work.
abureaux
MVP Regular Contributor
I believe your question is backwards. Try: regex(${mission_area}, area)
EDIT: Also, you don't need to use regex for this. You can also use selected(). E.g., selected(${mission_area}, area). Not a big deal since they are virtually identical in this scenario, but it's worth noting.
dwold
@abureaux thanks for the tip! That allows me to selected multiple mission areas but not all the core capabilities get populated with each additional selection. See anything else I am missing? If I select Recovery, I'd want Infrastructure Systems to appear but it currently does not. This is the case with all the Core Capabilities with multiple areas listed.
Infrastructure Systems doesn't appear if either Response or Recovery is selected. Neither do the top three core capabilities in the choices table
Anything in my choices table that looks wrong?
DougBrowning
