Using .dbf tables in Survey 123 Connect
689
06-26-2017 08:13 AM
ScottLouque
I have a bunch of features stored in feature classes and was wondering if I exported those tables out to a .dbf file and then converted the .dbf to a .csv file could I use it for display in Survey 123 Connect?
by Anonymous User
Not applicable
Hi stjman,
I believe this question is similar to one you also posted recently which I just followed up on. Can you please provide more information about the use case of the features/data in the .dbf file and how you want that "displayed" in Survey123 Connect? Are you wanting to create the structure of the survey based on the .dbf or are you wanting to import the data in the .dbf for use in choice lists?
Regards,
Phil.
