Hey Antonio Saavedra,
You can see a list of functions that use credits here: Understand credits—ArcGIS Online Help | Documentation
If you are referring to the survey123 app locating you on the map I don't believe that uses credits. I believe the only thing that uses credits is generating survey123 reports.
Thanks
Ben
If this answer was helpful please mark it as helpful. If this answer solved your question please mark it as the answer to help others who have the same question.
