Good day Doug and James
Thank you for the update.
I have upvoted those requests you suggested.
However, I got hold of an older excel survey form.
I used that as a template and was able to create a survey, a map and then
to create a new dashboard.
I updated the excel template with a new item under the choices list.
The survey was then republished and the newly added choice list item was
used when completing the survey.
The newly added choice item reflected in the map as well as in the
dashboard.
It looks like the excel spreadsheet form might be the obstacle in this
whole process.
Your ideas on this?
Sulette
