I have published a new survey using Survey123 Connect 3.7.62 and when I try to upload a .docx to the feature report I receive the following error: Error: Cannot read property 'layerName' of undefined
I have used the Survey123 Create Sample Template and I receive the same error on that template.
I have a feeling that a repeat is causing the issue, but even if I exclude the repeat section from the word doc I still get the error. I have tried publishing this report without the repeat section and I was able to use the create sample template and got it to work correctly.
Any help would be greatly appreciated....thanks!
