Thank you, that was very helpful. I was able to use the con tool to narrow down and then "intersect" my results. To further narrow down my search I've added a land use classification raster. I'm trying to use the con tool or the raster calculator to make it so that land classes that can't have solar panels are not included in the analysis. However, my knowledge of SQL is lacking and I can't form a correct SQL command (yet). I attached a picture to show you what I'm trying to do.
I only want to include the blue values in my analysis (and remove the red values). The white values have nothing in them. There are only three blue values - 21, 31, and 52. My SQL command is "USA_Land_use" == (21 & 31 & 52)
Any suggestions on how I might improve my SQL command?
