Copying a Utility Network from SDE to FGDB
2338
8
03-28-2020 04:56 PM
rbae
In ArcGIS Pro 2.5, I created a Utility Network with 2 Domain Networks in an SDE GeoDatabase.  When I try to copy the feature dataset containing the UN to a File GDB, it fails (around 3%) with the following error:
Does a UN require data before it can be moved?  It would be nice to be able to copy a blank UN to a FGDB for testing.
amayaesri
AnthonyRyanEQL
Ryan,
In the 'untools' toolbox there should a gp tool to export the asset package. Give that a go.
Good luck
PaulLeBlanc1
rbae
I export the asset package, then I have to import the asset package to the File GeoDatabase?  This requires me to have a functioning Utility Network in the File GeoDatabase first.
This is not what I want - I want an empty File GeoDatabase, with the ability to copy/paste everything that I have from an Enterprise GDB, including the utility network.
This is a simple function with the Geometric Network, and it just looks like a bug in ArcGIS Pro 2.5.
LarryYoung
Hi Ryan,
Exporting and importing an asset package is the current way to move utility networks from one geodatabase to another.
We are working on copy/paste capabilities, but do not expect them to be available for another release or two.
Sorry for the inconvenience.
Larry
rbae
Thanks Larry.  It's good to know that the functionality is on the way.
sjet1010
Any progress on this? I am using version 2.9 (Arcpro).
amayaesri
Hi sjet1010,
At ArcGIS Pro 2.9 we now have the XML workspace process.
https://pro.arcgis.com/en/pro-app/latest/help/data/utility-network/utility-network-dataset-administr...
RobertKrisher
According to the what's new in ArcGIS Pro 2.9 release notes you can not only use the xml workspace process, but you can also use a regular copy/paste to move the utility network dataset.
