How I can get/download the Utility Network Package Tools for Arcgis pro
5747
20
04-08-2020 01:43 PM
AlaaFlaifel
How I can get/download the Utility Network Package Tools for Arcgis pro?
Thanks in advance,
Alaa
PaulLeBlanc1
The Get Started tab has a link on how to install. Install the Utility Network Package Tools toolbox—Get Started | ArcGIS Solutions
AlaaFlaifel
Thanks Paul, I'll try it.
Z__NahideAydin1
New Contributor III
I installed the untools but I cannot find in the toolbox any of the packaging tools such as asset package to file geodatabase.
Help I am lost
PaulLeBlanc1
Can you open the python window in Pro (Analysis ribbon) and the run the following code?
import untools
print(untools.__version__)
That will confirm the version of untools you have installed.
Z__NahideAydin1
New Contributor III
this is what i got
import untools
File "<string>", line 1, in <module>
ModuleNotFoundError: No module named 'untools'
S I guess although it says it is installed it is not?
Z__NahideAydin1
New Contributor III
After I realized i don't have it I did the installation through python command window. Ans when I opened pro again I got an failed to load system tools error here is the screen shot
PaulLeBlanc1
Hmm, that usually means something happened to your cloned environment. You should probably create a new clone and try installing untools again.
Z__NahideAydin1
New Contributor III
Ok I'll try that and get back to you thanks for your help
Z__NahideAydin1
New Contributor III
Thank you so much for your help after i re did the clone it worked!
import untools
print (untools.__version__)
2.5.1
