Strangely enough when we tried to return the owner back to the original user the system errors that the input dataset must be branch versioned. Weird as this was in branch versioning.
Next is the re-enable branch versioning then try again. If that fails we will again attempt to return the owner to the original user.
I’ll keep you updated as we have seen the database change from branch to traditional without anyone actually changing this.
