Utility Network Package Tools disappear after upgrade to untools 2.5.1
1509
8
05-19-2020 07:06 AM
NeilEtheridge
New Contributor III
After upgrading to untools 2.5.1 the Utility Network Package Tools toolbox no longer appears on the Geoprocessing pane.  Is anyone else experiencing this?
Uninstalling 2.5.1 and reinstalling 2.5.0 (and restarting Pro) and the tools are available again.
MikeMillerGIS
Esri Frequent Contributor
The cloned 2.5 python environment is not valid with 2.5.1, you need to delete the clone, reclone it and then install the untools again
NeilEtheridge
New Contributor III
Thanks Michael for the very prompt reply!  I thought the same thing so have already been through that process, but didn't fix it.
by Anonymous User
Not applicable
Hey Neil,
Have you tried to install UNTOOLS using the command line?
Manoj
NeilEtheridge
New Contributor III
Yes tried this Manoj - no joy unfortunately
WillBooth1
New Contributor III
Hi Neil,
What Manoj suggested worked for me.
Cheers
Will
NeilEtheridge
New Contributor III
This might just be particular to my environment. After installing, untools is listed as version 2.5.1 in the installed packages list as you have shown here Will, but the "Utility Network Package Tools" toolbox is not available on the Geprocessing pane.  I think I will try uninstalling Pro completely next.
by Anonymous User
Not applicable
Neil, did you find a solution for this beyond a complete uninstall? I am experiencing the same thing. I have been able to successfully run the tools from the Python windows, however it would be nice to see the toolbox. Thanks!
NeilEtheridge
New Contributor III
Hi Jessy, sorry no I never did resolve the issue.  I usually access the tools through code which still works fine.
-N
