Attribute inspector no editable
1575
09-11-2014 02:29 PM
ionarawilson1
Occasional Contributor III
I have an application that is using the editor and the attribute inspector. I need to add a string showing the current date to a field. Everything works but after creating the feature and selecting it again I can see the string in that field in the attribute inspector but the attribute inspector is not editable anymore for that feature. Is it possible to add a string to a field and still have that feature editable in the attribute inspector? Thanks
  1. var    currDateTime:String = ""
  2. private function drawEnd(event:DrawEvent):void
  3.    {
  4.     dateFormatter.formatString = 'YYYY/MM/DD HH:NN:SS';
  5. currDateTime = String(dateFormatter.format(dtCurrent) + '.' + dtCurrent.getMilliseconds());
  6.
  7.    FeatureLayerstewardship.addEventListener(FeatureLayerEvent.EDI}TS_STARTING, editsStartingHandler);
  8.          }
  9.
  10.      private function editsStartingHandler(event:FeatureLayerEvent):void
  11.             {
  12.                 if (event.adds)
  13.                 {
  14.
  15.                     event.adds[0].attributes['DrawDate']  =  currDateTime;
  16.                 }
  17.
  18.
  19.             }
ionarawilson1
I fixed the issue! Just create a editscomplete event and refresh the feature layer and the attribute inspector!
protected function myFeatureLayerstewardship_editsCompleteHandler(event:FeatureLayerEvent):void
                myFeatureLayerstewardship.removeEventListener(FeatureLayerEvent.EDITS_STARTING, editsStartingHandler);
              myFeatureLayerstewardship.refresh();
              myEditor.attributeInspector.refresh();
ionarawilson1
