Attribute Table Widget
1680
7
10-22-2014 06:15 AM
denverweston
New Contributor III
Has anyone ran into an issue where the export does not work on the attribute table widget when you have multiple tabs?
RobertScheitlin__GISP
John,
   I just tested 4 tabs with some layers being polygon and some points and one of them with 3K+ records and they exported fine.
John,
   I have not noticed this. How many is multiple?
denverweston
New Contributor III
I have 4 tabs right now.
John,
denverweston
New Contributor III
Thanks.  I will keep playing with it.
denverweston
New Contributor III
So I have the attribute table working for a limited number of records.  It seems to not create the CSV after 40K records.
I don't know of a hard number that would be considered the max but I am not surprised the 40K is to much (this is not ArcMap for the web)
denverweston
New Contributor III
I understand that it is not ArcMap for the Web but at the same point our world is changing.  Our goal is to bring in live data for Emergency Responses and maybe it would be a good discussion point for the "Big Data" conversations.
