Is anyone else running into problems with SSL and flex apps? I've run this configuration on a test server that hosts both the app and services, with the services behind SSL, and that works ok. Now I want to run the app on a different server and hit the AGIS server via tokens and ideally proxyurl. However, regardless of the token generation or open crossdomain.xml on the AGIS server I continually get errors trying to access the https url. I'm hoping someone else out there is feeling my pain and had worked through this......... BTW I've tried with both a self-signed SSL and a legitimate domain SSL from a CA (although the server is not seen as on the same domain as the certificate i.e. public access name vs. internal name). I think browsers and AGIS hit a questionable SSL cert--the bright red warnings--and bomb out even if you choose to trust the site and install the certificate. Both IE and Chrome throw the cert. warnings....
