Isaiah, Well after looking into it deeper we can do all you need in just the PopUpRendererSkin.mxml. So here are the changes. override protected function commitProperties():void { super.commitProperties(); var featureLayer:FeatureLayer = hostComponent.featureLayer; var formattedAttributes:Object = hostComponent.formattedAttributes; var graphic:Graphic = hostComponent.graphic; var map:Map = hostComponent.map; var popUpInfo:PopUpInfo = hostComponent.popUpInfo; var validMediaInfos:Array = hostComponent.validPopUpMediaInfos; var geometry:Geometry = graphic ? graphic.geometry : null; var layerDetails:LayerDetails = featureLayer ? featureLayer.layerDetails : null; vGroup.removeAllElements(); //vGroup.addElement(ToggleLayers); if (popUpInfo) { if (popUpInfo.title) { titleText.text = StringUtil.substitute(popUpInfo.title, formattedAttributes); if (titleText.text) { vGroup.addElement(titleText); vGroup.addElement(titleLine); } } var htmlText:String; if (popUpInfo.description) { htmlText = StringUtil.substitute(popUpInfo.description, formattedAttributes); if (htmlText) { //Code Addition htmlText = replaceIsaiahsContent(htmlText); //End Code Addition var descriptionText:Text = new PopUpText(); descriptionText.percentWidth = 100; descriptionText.styleSheet = textStyleSheet; cleanAndSetHtmlText(descriptionText, htmlText); //trace(descriptionText.htmlText); vGroup.addElement(descriptionText); } } else { var descriptionForm:Form; for each (var fieldInfo:PopUpFieldInfo in popUpInfo.popUpFieldInfos) { if (fieldInfo.visible) { var formItem:FormItem = new FormItem(); formItem.label = fieldInfo.label || fieldInfo.fieldName; var label:Label; htmlText = formattedAttributes[fieldInfo.fieldName]; if (htmlText) { // convert attribute field values that just contain URLs into links var match:Array = htmlText.match(/^\s*((https?|ftp):\/\/\S+)\s*$/i); if (match && match.length > 0) { label = new Label(); htmlText = '<a href="' + match[1] + '" target="_blank">' + match[1] + "</a>"; } else { label = new PopUpText(); } cleanAndSetHtmlText(label, htmlText); label.selectable = true; label.styleSheet = this.textStyleSheet; label.width = 150; formItem.addChild(label); } if (!descriptionForm) { descriptionForm = new Form(); descriptionForm.percentWidth = 100; descriptionForm.horizontalScrollPolicy = ScrollPolicy.OFF; descriptionForm.verticalScrollPolicy = ScrollPolicy.OFF; descriptionForm.styleName = "formStyle"; } descriptionForm.addChild(formItem); } } if (descriptionForm) { vGroup.addElement(descriptionForm); } } if (validMediaInfos && validMediaInfos.length > 0) { vGroup.addElement(mediaBrowser); mediaBrowser.attributes = graphic.attributes; mediaBrowser.formattedAttributes = formattedAttributes; mediaBrowser.popUpFieldInfos = popUpInfo.popUpFieldInfos; mediaBrowser.popUpMediaInfos = validMediaInfos; } if (popUpInfo.showAttachments && graphic && featureLayer && layerDetails && layerDetails.hasAttachments && layerDetails.objectIdField) { vGroup.addElement(attachmentInspector); attachmentInspector.showAttachments(graphic, featureLayer); } if (map && geometry) { vGroup.addElement(zoomToButton); } } } //Code Addition private function replaceIsaiahsContent(content:String):String { content = content.replace("LMD 1","<a href='http://www.cityofrc.us/cityhall/admin/gis/districts/landscape/1.asp' target='_blank'><b>LMD 1</b></a>"); content = content.replace("LMD 2","<a href='http://www.cityofrc.us/cityhall/admin/gis/districts/landscape/2.asp' target='_blank'><b>LMD 2</b></a>"); content = content.replace("LMD 1, LMD 5","<a href='http://www.cityofrc.us/cityhall/admin/gis/districts/landscape/1.asp' target='_blank'><b>LMD 1</b></a>"); return content; } //End Code Addition
