Editor.as map_mouseUpHandler Error
864
6
08-04-2011 03:12 PM
MarkLittell
New Contributor III
I've customized the Editor Widget a great deal... and don???t see this error in the SFV.
While debugging in Eclipse using the Flex API 2.3.1... With the debugger off, there is no error.
If I select a polygon and then attempt to select another, I get the following error:
[INDENT]TypeError: Error #1009: Cannot access a property or method of a null object reference.
at com.esri.ags.components::Editor/map_mouseUpHandler() [/INDENT]
If I select the map (which un selects the polygon) between polygons, I do not get the error.
Any thoughts on how to remove the (I am guessing this is how to fix it) the map_mouseUpHandler listener?
I would really like to know where to obtain the Editor.as file!
I was hoping the 2.4 API would reveal more of the code behind regarding the Editor and FeatureLayers??? Oh well.
Suggestions are appreciated.
Thanks
MarkLittell
New Contributor III
My error is solved - after changing the event listeners around, I no longer get the error.
Still not sure what the exact issue was, but it is better now.
I'd still like to get access to the Editor.as code...
Thanks
Mark
RobertScheitlin__GISP
Mark,
   As the Flex API is NOT open source you will not get access to that code.
RedaKechouri
I'm developping a widget with editing capabilities, and I have the same error... It is quite annoying because it is difficult to pinpoint the cause of this error.
My guess is that there is a problem with the attribute infoWindow generated by the editor when an editable feature is clicked. And maybe the fact that I'm using another drawTool/editTool in my widget generates a conflict somewhere...
Any help would be much appreciated. Otherwise, I will just have to do some editing without the editor component.
Thanks
Reda
JoshWerts
New Contributor III
I'm having a similar issue working with the flex API editor component.  I get the problem when I try to remove the editor component.  It appears that the editor adds a mouse  up event listener to the map but doesn't clean up after itself when removed, thus causing a null exception when the event listener tries to reference the editor.
Anyone know if there's a way to remove the listener manually?
Josh
MehulChoksey
JoshWerts
New Contributor III
This issue with possible fix seems to be discussed here:
http://forums.arcgis.com/threads/26179-where-can-i-get-quot-Editor.as-quot?highlight=aniket
That worked!  Thanks!
