Solved! Go to Solution.
Hey all:
I am using the 3.0 version of the Edit Widget and running into problems. The widget sees my SDE feature layer, and allows me to add and delete features.
However, none of the fields in the layer display in the Attributes window (see the first attached screen capture). As a consequence, I cannot edit the attribute data and can only close the window or delete the feature. There's no OK button. Furthermore, any action I take using the widget freezes the screen, navigation tools, etc., and forces me to refresh the site.
Any edits i have made to the geometry are reflected only after I refresh.
In the service, there's a section called Templates that includes only two prototype attributes (see the second attached screen capture). Is this the problem?
I don't see anywhere in the SDE nor in the MXD where I can alter a prototype template. All of the fields in the feature class are editable; most, but not all, are turned on; there are a couple of domains for fields like County and MapStatus.
Here's the site: http://gis.ncdcr.gov/cleansite/default.htm?config=EditTest.xml
Feel free to test drive it. Please don't delete anything existing except the black X boxes or green check boxes though!
--ASE.
<operationallayers> <layer label="Unverified locations (50K)" type="feature" visible="true" alpha="1.0" url="http://gis.ncdcr.gov/ArcGIS/rest/services/Crowdsourcing/FeatureServer/0" popupconfig="popups/PopUp_Crowds.xml" > </layer> </operationallayers>
Hey all:
--ASE.
Error: Could not find compiled resource bundle 'ViewerStrings' for locale 'en_US'. at mx.resources::ResourceManagerImpl/installCompiledResourceBundle() at mx.resources::ResourceManagerImpl/installCompiledResourceBundles() at mx.core::FlexModuleFactory/installCompiledResourceBundles() at mx.core::FlexModuleFactory/docFrameHandler() at mx.core::FlexModuleFactory/docFrameListener()
