Robert,
Thank you for the quick response!
The State Plane WKID is in meters, so that shouldn't be the problem right? Either way I tried your suggestion regarding the UTM projection that covers my area with no luck. It works fine on the standard ESRI draw widget.
The problem isn't that the measurements are wrong, it's that they aren't showing up....does that matter?
Jason
