Enhanced-Search-Widget-for-FlexViewer Part II
94180
552
04-19-2012 08:03 AM
RobertScheitlin__GISP
All,
   I am pleased to announce the next release of my eSearch Widget.
http://www.arcgis.com/home/item.html?id=5d4995ccdb99429185dfd8d8fb2a513e
Version 2.5.1.7 - 4/19/2012
* Added ability to search (flat/standalone/no geometry) tables.
* This time all Zooming uses the same scaling (popup, datagrid, widget results, zoom to all).
* Added Relates icon/button to datagrids so that you can click on it in the datagrid to
  open relates choice dialog.
* Move all skins to a skins package for cleaner organization.
* Links that are not associated with a field now work.
* Ability to disable the relates tab in the fixed widget is now configurable.
MattShetzer
Thanks Robert for the quick reply.  We are getting ready to upgrade to API 3 in an month or two, and I will upgrade to the latest esearch widget at that point.  If I could request that in a future enhancement.  The biggest reason is the different display of the same data from the popups.
Thanks for all you do, and supplying an impressive search tool.
Matt Shetzer
Matt,
   Rounding is already a default in the 3.x versions
RobertMyers
In the Enhance Search Widget Sample App the Basemap "flyout", the Map Switcher widget, is on top of any open widget. However, running uncompiled download, it's behind all the widgets. Not sure how to correct this so it's on top.
Thanks.
RhettZufelt
MVP Frequent Contributor
Well, not sure if you can do anything about it with the compiled version.
However, if you have the capability to compile, see this thread:  http://forums.arcgis.com/threads/65432-(e)mapswitcher-widget-basemapsContainer-on-top?p=227012#post2...
R_
ClintBeccue
Robert,
The webADF had the capability to search the same field in different shapefiles (point, line , polygon).  Does this eSearch widget have that ability?
Thanks for your time and great work.
Clint Beccue
Clint,
   No the eSearch uses the QueryTask that only searches ONE rest endpoint. For you to search multiple you would have to build a widget using the findtask of the the Flex API. The problem with the find task is that you can not search spatially.
RobertMyers
R_
That did the trick. Thanks!
ClintBeccue
Thanks for your reply Robert!
RhettZufelt
Clint,
Curious if anyone following this thread knows of a findtask widget capable of doing this that one could get a hold of?
R_
LiamCollins
I have downloadeded version 3.0.16 of the eSearch Widget. When I bring eSearchWidget.mxml into flash builder I am getting 2 types of error across 4 lines of code shown below.
1046: Type was not found or was not a compile-time constant: SearchExpValueItem.
private function popCBwithUserList(userList:String, sItemVal:SearchExpValueItem):void
private function popCBwithSubType(sItemVal:SearchExpValueItem):void
private function popCBwithDomain(fieldName:String, sItemVal:SearchExpValueItem):void
1046: Type was not found or was not a compile-time constant: SearchResult.
public function clickSearchRelateResult(searchResult:SearchResult):void
I am using Flash Builder 4.6 with Flex Viewer 3.0 and API for Flex 3.0. I would appreciate any help as to where I am going wrong and what I need to do to rectify this issue.
Thanks in advance,
Liam.
