Hi Dan,
You'll need to make sure that you're printing the dynamic map service and not the feature layer. Geometry for a feature layer is returned using a query, whereas a dynamic map service exports a map image. Are you using the application builder? If so, just make sure to add the whole folder as an operational layer instead of just the sub layer.
-Daniel
