Feature Layer and Definition Expression
2563
03-08-2011 10:38 AM
PaulLang
New Contributor III
Within a Flex APP. Building a definition Expression from user into and tying it together is no big deal. I would like to do this in the Flex Viewer. How do I send the user input from my widger to a featurelayer within the Config.xml?
JonFisher
New Contributor III
Looks like you posted this in two threads by mistake. My reply:
You can either:
Use the QueryWidget (http://help.arcgis.com/en/webapps/flexviewer/help/widgets/query_widget.htm) and use the preload="open" tag to show a subset of a map service when the map loads, rather than just adding it as an operational layer.
Or, if using a feature layer, use the definitionexpression attribute as specified here:
http://help.arcgis.com/en/webapps/flexviewer/help/layer_tag.htm
PaulLang
New Contributor III
Thanks for the reply.
I can preset using this in the config:
           <layer label="NeighborhoodbyBldgQualityCode" type="feature" visible="false" alpha="1" definitionexpression="NBHDNUM='5b097'"
         url="http://gcgis/ArcGIS/rest/services/Monthly/NeighborhoodbyBldgQualityCode/MapServer/0" />
How can I send the NBHDNUM='5b097' from my user input into the config.xml?
private function doSearchBldgQualityCode():void
   {      NeighborhoodbyBldgQualityCode.definitionExpression = "NBHDNUM  ='" + qTextBldgQualityCode.text + "'";
ShannakaBeveridge
New Contributor II
I created this widget when trying to work out the same thing, hopefully it will help you out with what you want to do.
Cheers,
Shannaka
PaulLang
New Contributor III
Thank you so much, this helps me understand the communication process and gets the definition expression working.
